[KL730] BIE Conversion Crash (Err: 134) in AddDummyBnForSplitNode - LIAGCN Model
I am currently converting a skeleton-based action recognition model (LIAGCN) for the KL730. While the initial optimization stages (clean_opt) complete successfully, the process fails during the BIE (Backend Intermediate Expression) conversion with a hard assertion error in the compiler.
Stack trace (most recent call last):
#16  Object "", at 0xffffffffffffffff, in
#15  Object "/workspace/libs_V2/compiler/compile", at 0x62d1e7ce6f6d, in _start
#14  Object "/lib/x86_64-linux-gnu/libc.so.6", at 0x7f15d22ec082, in __libc_start_main
#13  Source "/projects_src/kneron-piano_v2/compiler/bin/compile.cc", line 82, in main
#12  Source "/projects_src/kneron-piano_v2/compiler/lib/common/public/compile_impl.h", line 62, in Compile(...)
#11  Source "/projects_src/kneron-piano_v2/compiler/lib/wagner/backend/compile.cc", line 311, in CompileImpl
#10  Source "/projects_src/kneron-piano_v2/compiler/lib/common/backend/compile_utils.cc", line 582, in GraphCompiler::OptimizeGraph()
#9 | Source "/projects_src/kneron-piano_v2/compiler/lib/common/frontend/graph_opt_fe.cc", line 58, in GraphOptFE(...)
#8 | Source "/projects_src/kneron-piano_v2/compiler/lib/common/frontend/optimization.cc", line 876, in OptimizeGraph(...)
#7 | Source "/projects_src/kneron-piano_v2/compiler/lib/common/frontend/optimization.cc", line 339, in AddDummyBnForSplitNode
#6  Source "/projects_src/kneron-piano_v2/compiler/lib/common/frontend/graph_modify.cc", line 298, in GraphModifier::InsertNewHeadBetween(...)
#5  Source "/projects_src/kneron-piano_v2/compiler/lib/common/frontend/graph_modify.cc", line 306, in GraphModifier::InsertBetween(...)
#4  Source "/projects_src/kneron-piano_v2/piano/lib/piano/graph/node_utils.cc", line 422, in GetOutLinkIdx(Node const*, Node const*, unsigned long)
#3  Object "/lib/x86_64-linux-gnu/libc.so.6", at 0x7f15d22fbfd5, in __assert_fail
