I am failing to run the "venc_dual" example.
I do followed the procedures below to run the venc_dual example:
1. Mount two IMX678 Sensor Boards on the EVM Board
2. Add a second imx678 node for mipi 2 and 3 to dtb
3. Create Directory 1 in Resource/VIC and add imx678_1920x1080_ch0.cfg and imx678_1920x1080_ch1.cfg to Directory 0 and Directory 1, respectively
4. Modify dual_conf.ini to reference imx678_1920x1080_ch0.cfg and imx678_1920x1080_ch1.cfg
5. Execte the command "./venc_dual -c dual_conf.ini"
At this time, I cannot resolve the following Error.
"E/[VMTK_VI] VMTK_VI_Init() Initialize VideoCap VML object fail"
Please check the attached Log file, Conf, and Source.
In addition to the previous content, this is the result of testing after modifying leipzig.dts to enable I2c2 and updating the dtb.
As we know, Seyeon Tech is cooperating with Sangrim Electronics. Since we have arranged direct support for Sangrim Electronics, please feel free to pass your question to Jay (@Sangrim Electronics).
