Error when attempting model editing (removing the softmax)
I have been following the example steps of "Build new model binary based on MobileNet v2", however I get the following error when trying to perform model editing:
root@7a5c0ba11c6e:/workspace# python scripts/onnx2onnx.py /workspace/data1/MobileNetV2.h5.onnx -o /workspace/data1/MobileNetV2-nosoftmax.h5.onnx
File "scripts/onnx2onnx.py", line 43, in <module>
m = combo.preprocess(m)
File "/workspace/scripts/tools/combo.py", line 54, in preprocess
m = optimizer.optimize(m, passes)
File "/usr/local/lib/python3.5/site-packages/onnx/optimizer.py", line 52, in optimize
optimized_model_str = C.optimize(model_str, passes)
RuntimeError: /onnx/onnx/optimizer/optimize.h:65: optimize: Assertion `it != passes.end()` failed: pass eliminate_nop_dropout is unknown.
Any help would be appreciated.
If you want to remove the op softmax, you can refer to the 3.1.7 Model Editor in Toolchain Manual http://doc.kneron.com/docs/#toolchain/manual/. And try onnx2onnx again to check your model after cutting the layer softmax.
Hi Ethon,
I have cut the the softmax layer from the mobilenet model. However, when I try to apply the onnx2onnx.py script to the updated model, I still see the error that I had mentioned in the original post:
root@7a5c0ba11c6e:/workspace/data1# python /workspace/scripts/onnx2onnx.py -o /workspace/data1/MobileNetV2.h5_nosoftmax_opt.onnx /workspace/data1/MobileNetV2.h5_nosoftmax.onnx
File "/workspace/scripts/onnx2onnx.py", line 43, in <module>
Any ideas how to fix this? Thanks!
Hi Tim,
Would you please provide the onnx or h5 for debug?
Hi Ethon,
Please find both in the tarball attached. Thanks!
Hi @Tim Gilmanov ,
What toolchain version you use?
the converted onnx you provided seems not match to our latest toolchain (v0.14):
yours:
expected:
Could you try the latest version toolchain?
The latest toolchain(v0.14) can successfully convert this model without error.
Here is my step:
Hi Eric and Ethon,
Thank you for looking into the issue and figuring out the problem.
I was able to get to the point where the model is optimized and the last Softmax layer is cut.
I am experiencing issues finishing up the tutorial of compiling the model for KL520 (6.3. Model Compile Flow (compile to .nef file)). See the details below.
Details about the docker container version:
(base) root@88aa0c3181b3:/workspace# more version.txt
kneron/toolchain:v0.14.1
The tutorial suggests the following step: Copy the /workspace/examples/batch_compile_input_params.json into /data1 and modify it before batch-compiling MobileNetV2.
However, this file is not available anywhere under the /workspace directory (the find command returns no results):
(base) root@88aa0c3181b3:/workspace# find /workspace -name batch_compile_input_params.json
I have copied the batch_compile_input_params.json from an older container version and tried to modify it according to the instructions:
(base) root@24546c406c46:/workspace/scripts# more /data1/batch_input_params.json
"input_image_folder": ["/data1/images"],
"img_channel": ["RGB"],
"model_input_width": [224],
"model_input_height": [224],
"img_preprocess_method": ["tensorflow"],
"input_onnx_file": ["/data1/MobileNetV2_opt.h5.onnx"],
"keep_aspect_ratio": ["False"],
"command_addr": "0x30000000",
"weight_addr": "0x40000000",
"sram_addr": "0x50000000",
"dram_addr": "0x60000000",
"whether_encryption": "No",
"encryption_key": "0x12345678",
"model_id_list": [1000],
"model_version_list": [1],
"add_norm_list": ["False"],
"dedicated_output_buffer": "True"
I then run the python script fpAnalyserBatchCompile_520.py which yields the error below:
python fpAnalyserBatchCompile_520.py
File "/workspace/scripts/utils/load_config.py", line 141, in __init__
for raw_config in self.config["models"]:
KeyError: 'models'
During handling of the above exception, another exception occurred:
File "fpAnalyserBatchCompile_520.py", line 43, in <module>
batch_config = BatchConfig(args.config)
File "/workspace/scripts/utils/load_config.py", line 146, in __init__
raise LoadConfigException(filepath, e.args[0])
utils.load_config.LoadConfigException: Error while loading /data1/batch_input_params.json: models is required but not found
Questions:
Hi Tim,
batch_input_params.json. I'm sorry for the wrong description of copying the configuration from a file. I'll update that part.
