[KL520DemoGenericInferencePostYolo][Error code] ApiReturnCode.KP_ERROR_USB_TIMEOUT_N7
My environment virtualbox + ubuntu 18.04
I run KL520DemoGenericInferencePostYolo.py but show
Error: upload model failed, error = 'Error raised in function: load_model_from_file. Error code: -7. Description: ApiReturnCode.KP_ERROR_USB_TIMEOUT_N7'
before run KL520DemoGenericInferencePostYolo.py, i was run List all devices & upgrade the selected KL520 devices using the port id as follows
(1) lsusb
Bus 001 Device 007: ID 3231:0100
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 002: ID 80ee:0021 VirtualBox USB Tablet
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
(2) ./KneronDFUT.sh --list
Index:      1
Port Id:   5
Kn Number:   0x9E0A225C
Device Type:   KL520
FW Type:   KDP2 Loader
Usb Speed:   High-Speed
Connectable:   true
(3) sudo ./KneronDFUT --kl520-flash-boot --port 5 --scpu ../../kneron_plus_v1.3.0/kneron_plus/res/firmware/KL520/kdp2_fw_scpu.bin --ncpu ../../kneron_plus_v1.3.0/kneron_plus/res/firmware/KL520/kdp2_fw_ncpu.bin
This update do not accept Hostlib version firmware. Downgrade firmware to earlier version is not acceptable after update.
Do you want to proceed? (y/n)
y
Start Update Device with Port Id 5 to Flash Boot
Segmentation fault
i suppose can't downgrade firmware so before run KL520DemoGenericInferencePostYolo.py, I mark upload firmware to device
   try:
       print('[Upload Firmware]')
       kp.core.load_firmware_from_file(device_group=device_group,
                                       scpu_fw_path=SCPU_FW_PATH,
                                       ncpu_fw_path=NCPU_FW_PATH)
       print(' - Success')
   except kp.ApiKPException as exception:
       print('Error: upload firmware failed, error = \'{}\''.format(str(exception)))
       exit(0)
python KL520DemoGenericInferencePostYolo.py
[Connect Device]
 - Success
[Set Device Timeout]
 - Success
[Upload Model]
    The issue could be caused by insufficient permission to access usb device.
    Please following the steps to set config for Kneron's device.
  • Hi
    之前環境是Virtual box + Ubuntu 18.04
    現在環境改成 win10 + python3.6
    (1) Run KL520DemoGenericInferencePostYolo.py -- OK
    [Connect Device]
     - Success
     - Success
    [Upload Firmware]
     - Success
    [Upload Model]
     - Success
    [Read Image]
     - Success
    [Starting Inference Work]
     - Starting inference loop 50 times
    [Retrieve Inference Node Output ]
     - Success
    [Tiny Yolo V3 Post-Processing]
     - Success
    [Result]
      "class_count": 80,
    (2) Run KL520DemoCamGenericInferenceDropFrame.py -- 是可以成功, 但是偶爾3~5秒後, 出現 ApiReturnCode.KP_ERROR_USB_TIMEOUT_N7
    [Connect Device]
     - Success
     - Success
    [Upload Firmware]
     - Success
    [Upload Model]
     - Success
    [Model NEF Information]
      "crc": "0x6CBF1FF9",
      "num_models": 1,
      "models": {
        "0": {
          "id": 19,
          "max_raw_out_size": 85752,
          "width": 224,
          "height": 224,
          "channel": 3,
          "img_format": "ImageFormat.KP_IMAGE_FORMAT_RGBA8888"
    [Configure Inference Settings]
     - Success
    inference time: 0.04555344581604004
    inference time: 0.030225038528442383
    inference time: 0.031000137329101562
    inference time: 0.03219795227050781
    inference time: 0.04864621162414551
    inference time: 0.027132511138916016
    inference time: 0.029174327850341797
    inference time: 0.031023740768432617
    inference time: 0.03415870666503906
     - Error: inference failed, error = Error raised in function: generic_raw_inference_receive. Error code: -7. Description: ApiReturnCode.KP_ERROR_USB_TIMEOUT_N7
     - Error: inference failed, error = Error raised in function: generic_raw_inference_send. Error code: -7. Description: ApiReturnCode.KP_ERROR_USB_TIMEOUT_N7
    遇到這樣問題後,需要把USB dongle插拔後才會正常..
  • 巫虹葦
    Hi 巫虹葦,
    想請您確認一下,您是使用 Kneron PLUS 的哪一個版本。
  • Hi
    您好..
    我是抓\kneron_plus_v1.3.0\ 這個版本 ..
  • edited April 2022
    巫虹葦
    Hi 巫虹葦,
    根據您貼上來的執行過程,您可能是有修改 python script,你可以先幫我試試看使用 "沒有修改的 python script" 是否會造成問題。
  • Hi
    您好..
    Sorry沒有敘述清楚,之前在Virtualbox+ubuntu18.04因為遇到一些問題,所以把uplaod Firmware的 code註解掉.
    但是換到win10環境後,沒有特別再去修改example的code了 ..
  • edited April 2022
    @巫虹葦
    Hi 巫虹葦,
    不好意思,我也沒有講述清楚,
    想請問您在兩個環境中
    (1) Virtual box + Ubuntu 18.04
    (2) win10 + python3.6
    執行 kneron_plus_v1.3.0 內 原來的範例(沒有修改過的 python scripts) 是否就會出現問題。
    python scripts eg. KL520DemoGenericInferencePostYolo.py,
    也想請您描述一下您在 Virtualbox+ubuntu18.04 是遇到那些問題呢,是你前面所描述的問題(下述的錯誤訊息)嗎?
    "Error: upload model failed, error = 'Error raised in function: load_model_from_file. Error code: -7. Description: ApiReturnCode.KP_ERROR_USB_TIMEOUT_N7'"
    然後提醒您 KL520 dongle 不用特別將  firmware 燒入到 Flash,您只要透過此 Kneron API (kp.core.load_firmware_from_file) upload firmware 到 Dongle 上就可以了,所以把 uplaod Firmware 的 code 註解掉是不行的。
  • Hi
    原來的範例(沒有修改過的 python scripts) 下
    出現
    [connect device]
    success
    [set Device timeout]
    success
    [Upload Firmware]
    Error code 10 ApiReturnCode.KP_DEVICE_NOT_EXIST_10
    Segmentation fault (core dumped)
    因為我一開始就遇到Upload Firmware失敗,所以我直接跳過Upload Firmware直接upload model,所以我一開始的問題才會是
    [Upload Model]
    因為環境是VirtualBox,排除環境的問題後,才改成在win10上嘗試,才有下一個問題.
    在win10上使用時候,有發現[Upload Firmware]的階段,會出現USB dongle unplug-in -> plug-in 的現象,再猜想在Virtual box + Ubuntu 18.04環境[Upload Firmware]時候,unplug-in後沒有自動plug-in上來才會出現 Error code 10 ApiReturnCode.KP_DEVICE_NOT_EXIST_10, 因為出現這個error後lsusb就看不到這個裝置了,必須手動拔插一 次才認得到USB裝置, 因為有這些問題,所以就暫時不關注在環境上,改成用win10 + python3.6嘗試
    python scripts eg. KL520DemoGenericInferencePostYolo.py, - 正常沒有問題
    python KL520DemoCamGenericInferenceDropFrame.py - 是可以成功, 但是偶爾3~5秒後, 出現 ApiReturnCode.KP_ERROR_USB_TIMEOUT_N7
  • edited April 2022
    @巫虹葦
    Hi 巫虹葦,
    您在兩個環境中
    (1) 您在 Virtual box + Ubuntu 18.04 上可能得先確認 Virtual box 是否有偵測到您的 KL520 dongle,有時候 Virtual box 會突然找不到 device.
    還有記得您的 KL520 不要使用以下指令去燒 firmware to flash,請以這個 API ( kp.core.load_firmware_from_file) upload KL520 firmware.
    (2) 您在 win10 + python3.6 執行 python KL520DemoCamGenericInferenceDropFrame.py,偶爾出現 ApiReturnCode.KP_ERROR_USB_TIMEOUT_N7 的時候,你的 camera 是否有持續的開著,然後螢幕上是否有畫面呢?
  • Hello
    您好.
    了解.. 不過我在win環境也透過Tool直接做燒錄,並且在win環境下執行KL520DemoGenericInferencePostYolo.py,把upload firmware mark掉,也是可以正常的upload model以及predict,我想我應該燒錄有成功吧 ??
    發生這問題時候,python的程式就 crashed,camera畫面也關掉了.
  • edited April 2022
    @巫虹葦
    Hi 巫虹葦,
    非必要時,我們並不鼓勵使用者 KL520 dongle 自己燒 firmware to flash,您可以參考以下資料。
    1. Introduction
    • Runtime Upload Firmware (USB Boot)
    3. Install Driver for Windows
    3.1 Use GUI to Update AI Device
    如果您需要順利成功執行範例,您的 dongle 插上,執行 DFUT GUI 可以看到如下圖
