無法將onnx模型編譯成nef格式
我在使用kneron toolchain且想將onnx 模型編譯成nef ,並且依照這個網頁內https://doc.kneron.com/docs/#toolchain/appendix/operators/ 查看支援的算子,但我已經排除了kl720不支援的算子,仍然有以下錯誤:
use toolchain binaries
Processing model: best
INFO:kneronnxopt:The input model has been checked. Start simplifying.
Checking 0/1...
INFO:kneronnxopt:Start independent preprocessing optimization passes.
INFO:kneronnxopt:Start shape preparation and optimizations.
INFO:kneronnxopt:Start operator related optimizations.
INFO:kneronnxopt:Start pattern related optimizations.
INFO:kneronnxopt:Start independent postprocessing optimization passes.
INFO:kneronnxopt:Comparing inference result between original/optimized ONNX... (add flag '--skip_check' if want to skip this step)
WARNING:kneronnxopt.checker:
Arrays are not almost equal to 4 decimals
Mismatched elements: 99 / 210000 (0.0471%)
Max absolute difference: 0.00024414
Max relative difference: 5.7531443e-06
 x: array([1.1304e+01, 1.7465e+01, 2.1873e+01, ..., 3.7253e-06, 2.3246e-06,
    3.4571e-06], dtype=float32)
 y: array([1.1304e+01, 1.7465e+01, 2.1873e+01, ..., 3.7253e-06, 2.3246e-06,
WARNING:kneronnxopt:The optimized model might not be correct.
Checking 0/1...
INFO:kneronnxopt.checker:Two models have the same behaviour.
ERROR:root: Failure for model "best_optimized/best_optimized" when running "kdp720/compiler frontend"
=      report on flow status    =
                     kdp720        general
               compiler frontend compiler_cfg clean_opt nef_model_id model oversize post_clean onnx size (MB)
category    case
best_optimized best_optimized     Err: 134      ✓     ✓    32768       ✓     ✓       9
[2025-11-25 15:24:10] [debug] [Thread: 834] [/projects_src/kneron-piano_v2/dynasty/floating_point/floating_point/src/common/BaseInferencerImpl.cpp:63]
start to create operators....
[2025-11-25 15:24:10] [debug] [Thread: 834] [/projects_src/kneron-piano_v2/dynasty/floating_point/floating_point/src/common/BaseInferencerImpl.cpp:102]
The model allocated space: 585.29252 Mbytes( including workspace: 0.0 Mbytes)
Section 3 E2E simulator finished.
                     kdp720        general
category    case
Workflow failed!
Quantization model generation failed. See above message for details.
在此附上我的模型以及編譯腳本
希望能幫我解惑,到底是哪裡有問題,導致無法編譯成功。
    感謝您回報此問題。我們建議您將optimized後的模型裡面Concat以下的operators剪掉之後再去做轉換,如下圖。您可以再把剪掉的operators加回去postprocess裡面。
    我想請問一下
    我在嘗試將基於 YOLOv8 的目標檢測模型部署到 Kneron KL720
    由於 KL720 硬體不支援 Softmax 算子,我將其替換為 4階泰勒展開 來近似
    那我optimized後的模型裡面Concat以下的operators在參考https://doc.kneron.com/docs/#toolchain/appendix/operators/ 都有符合硬體算子的限制
    也想要將模型全部都在npu上跑
    想請問是哪裡出沒有符合限制才導致無法轉換
    雖然模型的operators都有支援,但是onnx模型裡面的Slice導致Toolchain KL720的compiler無法轉換模型。我們嘗試剪掉operators後,就可以成功轉換了。因為KL720是一個比較舊的平台,會需要很多時間修改這些bugs,所以會建議您剪掉operators,或是更換模型,不好意思。
  • 了解了
    謝謝您
  • 不好意思
    我追問一下
    所以是編譯器有bug嗎
    還是我的onnx模型有問題,沒有符合編譯的限制??
    不好意思這麼晚回信,我們發現出問題的原因之一是mul的operator,所以有試著將它改為pow,但是修改完會遇到另一個reformat的問題,還有slice的維度問題,所以KL720用的編譯器有bug,模型也有不符合編譯的operators。
  • 我了解了
    謝謝您
