Segmentation fault running KneronDFUT
I am still trying to install everything. I am getting a Segmentation fault when I run KneronDFUT. I doesnt give me any more details than that. I am here in the install process:
Trying step 2 which should just display help info. How do I fix this?
Here is some more info on the error. Not sure what file it is talking about
(gdb) run
Starting program: /home/mycroft/Downloads/Kneron_DFUT/bin/KneronDFUT
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/arm-linux-gnueabihf/libthread_db.so.1".
Program received signal SIGSEGV, Segmentation fault.
0xb6fd86f4 in _dl_lookup_symbol_x (undef_name=0xb5649300 "pthread_create", undef_map=0xb6ff5948, ref=0xbefff034, symbol_scope=0x0, version=0x0, type_class=0, flags=3,
skip_map=0x0) at dl-lookup.c:806
806 dl-lookup.c: No such file or directory.
I did a clean install of the OS on my Raspberry. Getting this error now.:
Reading symbols from KneronDFUT...
(No debugging symbols found in KneronDFUT)
(gdb) run
Starting program: /home/mycroft/kneron/Kneron_DFUT/bin/KneronDFUT
/bin/bash: line 1: /home/mycroft/kneron/Kneron_DFUT/bin/KneronDFUT: No such file or directory
During startup program exited with code 127.
Please help
Hi Myron,
After downloading Kneron_DFUT_raspberry_pi_1.3.0 in the development center, please go inside the Kneron_DFUT/bin folder, then try running the Kneron_DFUT program by entering the ./Kneron_DFUT command. Please feel free to let us know if you have any other questions.
That is what I did to get the error. I downloaded Kneron_DFUT_rsapberry_pi_1.3.0.zip. When I run ./Kneron_DFUT I get the error above. Please help
Are you using RaspberryPi4? The DFUT tool only supports RPi4 now.
Yes, I am using a Raspberry PI 4.
Is there a way I can work around using this tool or away to debug it?
For the error you posted before "pthread_create", you can try to delete the file /Kneron_DFUT_rsapberry_pi_1.3.0/Kneron_DFUT/lib/libpthread.so.0 and execute again. The application will load system default library instead.
I tried that and it didn't work. I then added Kneron's lib to the path. I think we got further and got a different error. Now its looking for a different file:
(gdb) run
0xb6fd86f4 in _dl_lookup_symbol_x (undef_name=0xb564a300 "pthread_create", undef_map=0xb6ff5948, ref=0xbefff474, symbol_scope=0x0, version=0x0, type_class=0, flags=3, skip_map=0x0)
at dl-lookup.c:806
Maybe it a charter set issue. i.e. my Raspberry PI only has US-Eng loaded. Which charter sets do you have loaded on you Raspberry PI?
Any help?
Here is the PRi image created by Kneron. To make sure your environment, maybe you can find a new SD card to install with it and try again.
@Ethon Lin I tried that and I am getting the same error. I did run sp update first. Can you confirm you have a current version of a Raspberry PI able to update the firmware of the USB ?
Or you can build a console DFUT instead of pre-built DFUT GUI tool we provided.
step1: Download plus v1.3 here
https://www.kneron.com/en/support/developers/?folder=Kneron%20PLUS%20(incompatible%20successor%20to%20host_lib)/Kneron%20PLUS/&download=871
step2: And refer to the document, the steps on RPi should be the same with on ubuntu.
Or you can just follow the commands below:
$ cd kneron_plus/
$ mkdir build
$ cd build/
$ cmake -D WITH_DFUT=ON ..
$ make -j
Then you will find the executive "DFUT_console" in /kneron_plus/build/bin
All functions on DFUT can be used by DFUT_console, too.
@Ethon Lin that worked! Thank you
